peerless pigtails
That's alot of protection . But well worth it , considering the cost of the controls on the ends of 'em .
Alot of the steamers we install don't come with pigtails anymore . Pressuretrols too . I like the idea of using larger nipples and tees and ells to make your own pigtail . Less of a chance of clogging up .
peerless pigtails
for what it is worth, here is how i increased the vaporstat protection on my peerless 211-a which did not come with pigtails, but is meant to be protected by their version of a steam syphon.
if one is good then maybe 2 are better!--nbc0 -
piggies
i wanted to have room for 2 vaporstats [ in case i go ahead with a 2-stage burner], a high-limit pressuretrol, and a low pressure gauge, so i needed that length, and height above the waterline. if the v-stat is too low then it interfers with skimming by feeling the elevated waterline height, and cutting off the flame. longer vertical nipples would have worked, but were flimsy.--nbc0 -
why
I think the reason they do not come with them anymore is like here in PA the piggys must be non ferrus meaning brass and well that adds a buck or two and we just cant have that now can we?0 -
non-mercury vaporstats?
I notice the pigtail donut hole direction; I'm guessing the vaporstats do not use mercury. Not meaning to be nit-picky but nowadays pictures can be potentially confusing with both mercury and non-mercury vaporstats in operation.0 -
compound wrench--a beauty
that compound wrench is worth more than a few shekels. do ya know how to use it ??0 -
compound wrench
it's from e-bay, and i will use it to remove the caps on the nipples into the mud-leg area this summer, to give a good cleaning "behind the ears".
more sheckals to ship than buy!--nbc0 -
vaporstats
What is the model # of the vaporstats you used? Where can I find a gauge that reads 0 - 5 psi? Thanks for your help!0 -
low pressure gauge
gaugestore.com0 -
hey nbc
newbie question here; why do steam pressure gauges have a vacuum side? under what conditions will the boiler run in a vacuum; and why would we need to know that/when would we catch it doing that?0 -
vacuum
when the radiators, pipes, and the boiler are full of steam, with all the air having been driven out; and then the burner cuts off, the steam condenses rapidly. now you have a vacuum which must be relieved. the main vents do most of this, with a little help from the radiator vents. this yet another reason why the main vents are so important for comfortable, quiet, and economical steam systems--nbc
you can read about old systems that ran at subatmospheric pressures in "the lost art of steam heating" available here. unfortunately they functioned better with coal boilers than modern gas/oil boilers, so are not now much in use.0
- 167 Indoor-Air Quality
