Humidity
Empire_2
Member Posts: 2,340
What area are you in? Usually the Hi rel hum% is very low in eastern states. Also, what are you considering hi RH%?
Mike T.
Mike T.
humidity
Time after time when something goes wrong in the house call the HVAC contractor. I am looking for a reasonable resource for customers complaining about high humidity when they don't even have humidifiers. The builder tells them to call us for the answer and I would like to be able to give them an answer based upon facts. House too tight, make up air, etc.
Please help!0 -
Humidity
Are we talking about high humidity in the heating mode or in the cooling mode. High humidity in the cooling mode is a telltale sign of an oversized system.
You might want to check out this little article:
http://www.heatinghelp.com/newsletter.cfm?Id=1700
