Electric backup for high efficiency boiler
i have a 1500 va ups [from best buy] on my gravity steam system.
the electrician wired a special switch and outlet for it so i can have the boiler powered through the ups, or straight from the house wiring.
we used to have fairly frequent outages before then.now with the ups--not one in a year!!-nbc
  • Andrew_22
    Andrew_22 Member Posts: 4
    Loved the books I bought, big help in reducing my water hammer. Now that I have a high efficiency boiler, when the power goes out, I'm hosed. As I understand it, the electricity requirements for the boiler are pretty minimal, so I'm wondering what the options are for a small electric backup for brief power outages. Will a small battery system suffice, or should I be looking at generators?
    Thanks much!
  • Andrew_22
    Thanks, this sounds perfect since my system is a one floor gravity steam system. How long an outage have you been able to sustain with this setup?
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    Amp draw
    Which Boiler are you using?
    And what is the Amp Draw of it and the Amp Draw of the Circulating pump?
    I have used a UPS from "Office Max" which keeps systems running for an Hour or Two depending on the boiler/Circ. operation.
  • UPS
    my boiler is a peerless 1,050,000 1-pipe steam, entirely gravity, so its current draw is low.
    i haven't made a test yet.before the boiler went in last year, we had 1 power cut a month.since that time--no cuts!!
    it's a 1500 va.--nbc
