valve picture & question
Like a lubricated plug cock. Or maybe just a plug cock. in eather case, yes, you should beable to close this to isolate. It might also have a built in check, but i dont belive so, can you try another picture?
  • rick_27
    rick_27 Member Posts: 11
    Valve picture and question
    what type of valve ,balance can i close this to isolate .first time with camera phone on 3 way mixing valve
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    looks like a flowcheck to me but kind of a grainy picture. is there a nipple and cap off the bottom? How is the water flowing into and out of this thing?
    cell # 413-841-6726
  • I tried to lighten it up,
    but still not very good.
    My guess is some sort of PRV with built-in strainer that can be cleaned through the top?
    Dave
  • Rich Kontny_3
    Rich Kontny_3 Member Posts: 561
    Dezurik
    Looks like a Dezurik or equivalent plug or balancing valve. Crane, Hammond and others made plug valves also.
  • rick_27
    it does feed hot water coils .i believe balancing valve the picture is upside down sorry there is a gate valve on supply to mixing valve and this is on the return ,i have only run into these once .can this be used to isolate if i cahanged mixing valve dont want to get into mess
