Solar Control
klaus
Member Posts: 183
Solar system and heating circuit "reverse raising" Solar storage through Boiler with 3 way valve. I am not undestanding this design concept. Why run the already heated solar storage water through the boiler, and then to the heating circuit's.
Why waste precious BTU's....
Pipe it primary secondary with independent input loops from the solar.
ME0 -
Would you need
a heat exchanger on the solar input loops. You can't mix the solar fluid with the boiler fluid.0 -
That was my original plan. Thanks.0 -
STorage Tanks Have dual Coils.0
- 167 Indoor-Air Quality
