Solar Control
klaus
klaus Member Posts: 183
Solar system and heating circuit "reverse raising" Solar storage through Boiler with 3 way valve. I am not undestanding this design concept. Why run the already heated solar storage water through the boiler, and then to the heating circuit's.
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    Why waste precious BTU's....
    Pipe it primary secondary with independent input loops from the solar.
    ME
  • Mike Dunn
    Mike Dunn Member Posts: 189
    Would you need
    a heat exchanger on the solar input loops. You can't mix the solar fluid with the boiler fluid.
  • klaus
    That was my original plan. Thanks.
  • klaus
    STorage Tanks Have dual Coils.
