TRV Recommendation
with the vacuum breaker. Available from Tunstall in Chicopee.
Keep in mind, Steve, that you need a straight, not angle pattern vent with any brand of these. So, if your Gortons are angled, you will have to get new straight-pattern ones OR use brass nipples and an elbow to make the angle pattern vents work. It will look a tad stupid, but it can be done.
