TRV Recommendation
Brad White_202
Member Posts: 105
with the vacuum breaker. Available from Tunstall in Chicopee.
Keep in mind, Steve, that you need a straight, not angle pattern vent with any brand of these. So, if your Gortons are angled, you will have to get new straight-pattern ones OR use brass nipples and an elbow to make the angle pattern vents work. It will look a tad stupid, but it can be done.
TRV Recommendation
Can someone recommend a specific TRV for steam radiators that will work with the Gorton air vents that I already have? I would rather have a recommendation, having never used one.
Thanks,
SteveSteve from Denver, CO0 -
Steve-
Here several sites that might be of help to you.
https://www.heatinghelp.com/newsletter.cfm?Id=101
http://na.heating.danfoss.com/PCMPDF/RA2000 1PS-DS.pdf
http://www.maconcontrols.com/pdfs/OPSK1204.pdf0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 99 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 53 Water Quality
- 41 Industry Classes
