indirect water heaters
Bob C_3
Bob C_3 Member Posts: 1
I have a choice to make. Do I purchase a titanium type, stone lined or stainless steel tank. I'm told the stainless steel dont last...leaks have been known..Thanks for your help.
Bob
  • Mark Custis
    Mark Custis Member Posts: 537
    More input needed
    What are you doing with the water? DHW? What are you going to indirectly heat the water with?
  • bob eck
    bob eck Member Posts: 930
    check out the new burnham alliance indirect water heater it is stone lined with 10 year warranty on tank and home owner can pay extra direct to burnham to make it a lifetime warranty on the tank.
    their Al35SL delivers 120 GPH first hour of 135* hot water.
    check out Heat Transfer Products they have a solar tank with a bottom coil that can be hooked up to solar panels and the top coil hooked up to the boiler as a back up.
  • ChasMan
    ChasMan Member Posts: 474
    Titanium?
    Who mkes Titanium Indrects?
  • Rich Kontny_3
    Rich Kontny_3 Member Posts: 561
    Triangle Tube
    Triangle Tube makes some of the best and their heat transfer methods are very fast and simple. The tolerances and restrictions in some indirects create the need for larger pumps and relative turbulence noise.
    Triangle did get some bad press regaring some weld failures however I believe they corrected that problem.
    Rich
  • clammy
    clammy Member Posts: 3,242
    turbomax 2000
    bob check out turbomax 2000 nice unit and very good recovery
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
