indirect water heaters
Bob C_3
Member Posts: 1
I have a choice to make. Do I purchase a titanium type, stone lined or stainless steel tank. I'm told the stainless steel dont last...leaks have been known..Thanks for your help.
Bob
Bob
More input needed
What are you doing with the water? DHW? What are you going to indirectly heat the water with?0 -
check out the new burnham alliance indirect water heater it is stone lined with 10 year warranty on tank and home owner can pay extra direct to burnham to make it a lifetime warranty on the tank.
their Al35SL delivers 120 GPH first hour of 135* hot water.
check out Heat Transfer Products they have a solar tank with a bottom coil that can be hooked up to solar panels and the top coil hooked up to the boiler as a back up.
Titanium?
Who mkes Titanium Indrects?
Triangle Tube
Triangle Tube makes some of the best and their heat transfer methods are very fast and simple. The tolerances and restrictions in some indirects create the need for larger pumps and relative turbulence noise.
Triangle did get some bad press regaring some weld failures however I believe they corrected that problem.
Rich0 -
turbomax 2000
bob check out turbomax 2000 nice unit and very good recoveryR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
