Monoflow Tees
Does anybody know where I can get iron 3/4" monoflow tees?
We have a customer with a building full of them with the insides rotted out. Any other suggestions?
  • IPS Monoflo
    Tough to find now days. Velocity must have been a big prob there?
    Orifices are available to make-up your own but whether they will fit in the existing tees, and how to remove the old, I don`t know.
    Dave
  • Big Ed_4
    Big Ed_4 Member Posts: 3,369
    Another Way
    Say you have a 1" main with 1/2" risers , use two 1"x3/4"x1/2" tee and run a 3/4" pipe between the tee's .
    I think you have a 3/4" main with 1/2" risers, I would use two 3/4"x1/2"x1/2" tee and run a 1/2" pipe between the tee's
  • bob_46
    bob_46 Member Posts: 813
    Another Way
    Or you can put a Circuit-Setter between the risers.
