Monoflow Tees
![[Deleted User]](https://secure.gravatar.com/avatar/8532db4b9e4bf71c993867e8fe2f2ace/?default=https%3A%2F%2Fvanillicon.com%2Fb7bae1c36d34898162a6e5e59d78b301_200.png&rating=g&size=200)
[Deleted User]
Does anybody know where I can get iron 3/4" monoflow tees?
We have a customer with a building full of them with the insides rotted out. Any other suggestions?
IPS Monoflo
Tough to find now days. Velocity must have been a big prob there?
Orifices are available to make-up your own but whether they will fit in the existing tees, and how to remove the old, I don`t know.
Dave0 -
Another Way
Say you have a 1" main with 1/2" risers , use two 1"x3/4"x1/2" tee and run a 3/4" pipe between the tee's .
I think you have a 3/4" main with 1/2" risers, I would use two 3/4"x1/2"x1/2" tee and run a 1/2" pipe between the tee'sThere was an error rendering this rich post.
Another Way
Or you can put a Circuit-Setter between the risers.There was an error rendering this rich post.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
