Monoflow Tees
[Deleted User]
Does anybody know where I can get iron 3/4" monoflow tees?
We have a customer with a building full of them with the insides rotted out. Any other suggestions?
IPS Monoflo
Tough to find now days. Velocity must have been a big prob there?
Orifices are available to make-up your own but whether they will fit in the existing tees, and how to remove the old, I don`t know.
Dave0 -
Another Way
Say you have a 1" main with 1/2" risers , use two 1"x3/4"x1/2" tee and run a 3/4" pipe between the tee's .
I think you have a 3/4" main with 1/2" risers, I would use two 3/4"x1/2"x1/2" tee and run a 1/2" pipe between the tee'sThere was an error rendering this rich post.
Another Way
Or you can put a Circuit-Setter between the risers.There was an error rendering this rich post.
- 167 Indoor-Air Quality
