booster fan
Gene_8
Member Posts: 5
hook up booster fan to a variable speed furnance
No see-um
question.0 -
it was posted in general questions earlier
his EAC terminal is always powered, and I do not know if he needs only for heat (therefore using the HUM term) or not.
Several questions were posted, but I heard nothing.
EAC terminal
is powered when blower is on for any reason. I wouldn't hook booster up directly but use a 120V coil relay to interface.0 -
@ words to make it simple
Adjustable pressure switch, easy as pie.::) It's a simple form of controlling your in line booster fan and can be adjusted to either a positive (preferred) or negative actuation. Even on your lowest VAr. speed, you can initiate the fan to come on at will. I assume this in a very long run and has been a problem from day one?.....
Mike T.....
PS Hey Brad? I'd been away for a while,....Keep bringing your insite!0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
