booster fan
hook up booster fan to a variable speed furnance
  • No see-um
    question.
  • Mitch_4
    Mitch_4 Posts: 955
    it was posted in general questions earlier
    his EAC terminal is always powered, and I do not know if he needs only for heat (therefore using the HUM term) or not.
    Several questions were posted, but I heard nothing.
  • EAC terminal
    is powered when blower is on for any reason. I wouldn't hook booster up directly but use a 120V coil relay to interface.
  • Empire_2
    Empire_2 Posts: 2,340
    @ words to make it simple
    Adjustable pressure switch, easy as pie.::) It's a simple form of controlling your in line booster fan and can be adjusted to either a positive (preferred) or negative actuation. Even on your lowest VAr. speed, you can initiate the fan to come on at will. I assume this in a very long run and has been a problem from day one?.....
    Mike T.....
    PS Hey Brad? I'd been away for a while,....Keep bringing your insite!
