To be or not to be Nate Certified
klaus
klaus Member Posts: 183
What is more important when replacing a boiler for a one pipe steam system? That my contractor is Nate certified in Hydronics or his experience with steam boiler / radiator systems?
  • ed wallace
    ed wallace Member Posts: 1,612
    to be nate certified or not
    more important that installer knows steam and does job in black iron
  • paul_91
    paul_91 Member Posts: 62
    ex
    being nate certified is really good..but go with experience first
  • paul_91
    ex
  • Norm Harvey
    Norm Harvey Member Posts: 684
    Ask to see his portfolio. If he is proud of his work he will take pictures. That's one way of separating someone who does this work as their livelihood and someone that does this as their job.
    Like the others, I would go with steam experience. Also if they recognise the name "Holohan" that's a good start.
  • Eugene Silberstein 3
    Eugene Silberstein 3 Member Posts: 1,380
    To NATE or not to NATE
    As a NATE proctor, professor and one who has seen the good, the bad and the really ugly, NATE certification is a really good thing to look for, but is not intended to replace field experience and expertise. As a matter of fact, the NATE testing process is comprehensive enough that, if an individual is NATE certified, you can be quite comfortable knowing that the individual possesses the "textbook" knowledge of the area being evaluated.
    keep in mind that the NATE exams are multiple choice examinations and some individuals are better test takers than others. I have encountered excellent technicians who have taken NATE exams multiple times and have not earned passing scores. I have also had techncians relatively new to the industry pass a NATE test on the first try.
    In my opinion, NATE certitification is a great credential, but do not base your decision about whether or not to use a contractor soley on it.
    Hope this helps.
    Professor Eugene Silberstein
  • GW
    GW Member Posts: 5,065
    nate
    I did the NATE ac cert. I am not a smart AC guy, but I proudly know much more than the plumber that knows the difference between a liquid and suction line. Simply put, I know what I don't know.
    Nate is likened to going to college: it is a public display that you can think- that's all.
    I'm quite sure I've bagged some jobs because of nate.
    gary
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
