How do you tell if your tank has a bladder or not?
Jim Balduc
Member Posts: 3
The tank is 51 inches long by 12 inch diameter.
Bladder or no bladder
How do you tell if your expansion tank has a bladder or not. Mine has the threaded nipple pointing down. Do I bleed it by taking the nipple out? My system is leaking out the relief valve overhead. Thank you.0 -
if its...
long (24"- 36" and hung above the boiler... no bladder
if its "about" the size of a gallon 1/2 container...bladder0 -
Expansion tank
The tank is mounted up next to the ceiling above the boiler. Thanks Again0 -
no bladder...
in that one.0
- 167 Indoor-Air Quality
