How do you tell if your tank has a bladder or not?
![Jim Balduc](https://secure.gravatar.com/avatar/60247709ad86e3df58e1a08a219cea2b/?default=https%3A%2F%2Fvanillicon.com%2Ff7e2a0068639886be19555a6e1935c81_200.png&rating=g&size=200)
Jim Balduc
Member Posts: 3
The tank is 51 inches long by 12 inch diameter.
Bladder or no bladder
How do you tell if your expansion tank has a bladder or not. Mine has the threaded nipple pointing down. Do I bleed it by taking the nipple out? My system is leaking out the relief valve overhead. Thank you.0 -
if its...
long (24"- 36" and hung above the boiler... no bladder
if its "about" the size of a gallon 1/2 container...bladder0 -
Expansion tank
The tank is mounted up next to the ceiling above the boiler. Thanks Again0 -
no bladder...
in that one.0
- 86.7K THE MAIN WALL
- 54 Biomass
- 101 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 934 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
