How do you tell if your tank has a bladder or not?
The tank is 51 inches long by 12 inch diameter.
  • Jim Balduc
    Jim Balduc Member Posts: 3
    Bladder or no bladder
    How do you tell if your expansion tank has a bladder or not. Mine has the threaded nipple pointing down. Do I bleed it by taking the nipple out? My system is leaking out the relief valve overhead. Thank you.
  • kpc_40
    kpc_40 Member Posts: 62
    if its...
    long (24"- 36" and hung above the boiler... no bladder
    if its "about" the size of a gallon 1/2 container...bladder
  • Jim Balduc
    Expansion tank
    The tank is mounted up next to the ceiling above the boiler. Thanks Again
  • kpc_40
    no bladder...
    in that one.
