To Fill or Not to Fill
irv_3
irv_3 Member Posts: 7
Guys,
I am starting my steam system for the season. Everything is working well, however the sight glass on the LWCO is showing signs of rusty water. I didnt expect it to be clear.
I read from past posts that changing a lot of water would accelerate the life of the boiler. Whats the best way to get the water back to a clearer condition?
Thanks,
Irv
  • Timco
    Timco Member Posts: 3,040
    There is a small drain valve on the bottom of the lower sight glass holder. Open it and see if the rusty water drains out and clears up before draining or skimming.
    Tim
    Just a guy running some pipes.
