Pipe size
Steamhead (in transit)
Member Posts: 6,688
1-inch minimum for the runout, and I'd pitch it down and vent and drip the end. Run the drip back to a wet return. Going counterflow here may produce banging unless you could get some serious backward pitch!
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Pipe size for steam
I'm looking at adding a 6 foot section of cast iron baseboard. The pipe run will be 24 feet. Is that to long for 3/4 pipe?
Thank you
Mark0 -
It looks like I can get about a 4" drop in 20 feet. If I go with an 1-1/4 or 1-1/2 pipe and use a 3/4 riser up through the floor. Do you think that will work. Or will I just be making problems for myself.0 -
is this for steam or hot water0 -
2 way street
Can you construct a 2 way street just 12' wide?
will traffic flow safely and smoothly both ways?0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 971 Plumbing
- 386 Solar
- 17 Recall Announcements
