Pipe size
1-inch minimum for the runout, and I'd pitch it down and vent and drip the end. Run the drip back to a wet return. Going counterflow here may produce banging unless you could get some serious backward pitch!
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • World Plumber
    World Plumber Member Posts: 389
    Pipe size for steam
    I'm looking at adding a 6 foot section of cast iron baseboard. The pipe run will be 24 feet. Is that to long for 3/4 pipe?
    Thank you
    Mark
  • World Plumber
    It looks like I can get about a 4" drop in 20 feet. If I go with an 1-1/4 or 1-1/2 pipe and use a 3/4 riser up through the floor. Do you think that will work. Or will I just be making problems for myself.
  • is this for steam or hot water
  • Hitzkup
    Hitzkup Member Posts: 63
    2 way street
    Can you construct a 2 way street just 12' wide?
    will traffic flow safely and smoothly both ways?
