Reflective panels
David Nadle
David Nadle Member Posts: 624
I read in a Popular Mechanics book that up to 25% of a radiator's output goes through the wall and out of the house. They recommend putting a reflective material such as sheet metal or foil behind the radiator to reflect that back into the room.
For those in the trade, my question is: how often do you come across these in the field, and do you ever recommend them to customers?
  • KCA_2
    KCA_2 Member Posts: 308
    My Office
    Used to be out of a 1950's ranch home. We retrofitted the old (2) gravity furnaces with radiators and in-floor radiant heating.. I mean.. what else would I do..LOL..
    Anyway.. When we installed the rads I made a point to install some al. foil. behind the rads and left one without to use as a bench mark.. Wonderful results.. :)
    I've also used in-wall radiant before and always use a reflective material between the system and the cold temp. whatever it might be....
    Also I recommend painting the roof with a reflective paint before roofing.. :)
    Fun stuff...
    :-) KC
    :-) Ken
  • Ted G
    Ted G Member Posts: 63
    I think this is especially important with radiator recessed into the walls. If you have insulated walls and rads on the inside, I see no reason for the reflective material.
  • TR
    TR Member Posts: 40
    reflective panels
    I moved into a house with steam radiators and the first thing I did was install 1/2 rigid foam insullation behind each one. The local home center had 4x8 sheets with an alumimum face on one side. I cut panels slightly larger than each radiator and slid them between the wall and the back of the radiator.
    All I can tell you is that the rooms heated up just fine and the plaster walls behind the insualtion panels were always really cold. Give it a try - your heating bill will be lower but I have no way of knowing if 25% is the actual heat-loss.
    TR
