Reflective panels
David Nadle
Member Posts: 624
I read in a Popular Mechanics book that up to 25% of a radiator's output goes through the wall and out of the house. They recommend putting a reflective material such as sheet metal or foil behind the radiator to reflect that back into the room.
For those in the trade, my question is: how often do you come across these in the field, and do you ever recommend them to customers?
My Office
Used to be out of a 1950's ranch home. We retrofitted the old (2) gravity furnaces with radiators and in-floor radiant heating.. I mean.. what else would I do..LOL..
Anyway.. When we installed the rads I made a point to install some al. foil. behind the rads and left one without to use as a bench mark.. Wonderful results..
I've also used in-wall radiant before and always use a reflective material between the system and the cold temp. whatever it might be....
Also I recommend painting the roof with a reflective paint before roofing..
Fun stuff...
:-) KC
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional":-) Ken0 -
I think this is especially important with radiator recessed into the walls. If you have insulated walls and rads on the inside, I see no reason for the reflective material.0 -
reflective panels
I moved into a house with steam radiators and the first thing I did was install 1/2 rigid foam insullation behind each one. The local home center had 4x8 sheets with an alumimum face on one side. I cut panels slightly larger than each radiator and slid them between the wall and the back of the radiator.
All I can tell you is that the rooms heated up just fine and the plaster walls behind the insualtion panels were always really cold. Give it a try - your heating bill will be lower but I have no way of knowing if 25% is the actual heat-loss.
TR0
- 87K THE MAIN WALL
- 57 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 990 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
