SmartFilter 0-5 after changing tank filter
Rich P_3
Rich P_3 Member Posts: 34
Smart filter is compatible with Garber or Westwood
Get it at your heating wholesaler
I have never used an automobile filter
Something is up with the vac gauge going to to 5
is this a gravity flow (tank at same level) as burner?
can you get oil to flow by itself or does it need to be pulled by fuel pump? Flush oil line before staring burner.
good luck
rich
  • Michael_37
    Michael_37 Member Posts: 18
    ek smart filter 0 to 5 after changing filter on tank
    The vacuum gage on my ek smartfilter went from 0 to 5 after changing the filter on the oil tank. I must have released a bunch of crap :(
    Where to get the ek smart filters or compatible ? These are not a home depot product, Autozone ??
