retro
don_205
Member Posts: 66
You left out the head.You made get 15 gpm out of it if the pump was only seeing 5 feet of head.
Personally as a service tech I would love to see more differential by-pass valves when using zone valves.Nothing like walking up on a zones system with one huge pump and hearing a noise thru out the house when only one zone is calling.
Oh no...its got type m copper and short radius ells too.
what would you do ?
I'm still learning this stuff. I don't have much problem when designing from scratch. I run into issues with retrofits. This is for a simple boiler replacement that I'm choosing to over think. here is my situation:
I have 3 zones that are high temp baseboard. I figured all gpm to be 2 fps
Zone 1 - heat load is 37,259 btu
Supply & return common pipe is 1" that splits into two 3/4" loops
@ 5.5 gpm my DT is 13.5
Zone 2- load @14,688
3/4" loop
@ 3.2 gpm DT is 9.18
zone 3- load @ 16,660
3/4" loop
@ 3.2 gpm DT is 10
A 007 can pump up to 15 gpm so I'm thinking that zone valves may be good. However (if I remember correct) Robert Bean stated that the threshold for using circs over valves is when the zone is over 4 gpm.
Should I zone w/ valves or pumps ?
If I piped both supply & returns into a common header would I make that 1 1/2" ?
At 12 gpm,
a 007 will push a max. of 7 ft. of head; a 0010 will push a max. 0f just less than 10 ft. of head. Baseboard has a low pressure drop, but since this is a retrofit and you really don't know what's out there in terms of pipe and fitting, I'd go with circs. to play it safe.
one pump
To take the guess work out of it I would use a Wilo-Stratos ECO and use zone valves or ideally TRV's and do constant flow. The Wilo is a little little pricey but well worth it especially if you did zone pumping.0
- 167 Indoor-Air Quality
