current gas & oil costs in your area??
V8toilet
V8toilet Member Posts: 71
Right now NG is about $1.25 per therm with delivery charges.
  • tim smith
    tim smith Member Posts: 2,875
    current natural gas & oil costs in your area??? Tim
    looking to see how rates compare in different parts of the country, for the heck of it. Tim Re: 1st reply, sorry, should have identified. Thanks for the reply.
  • Carol_9
    Carol_9 Member Posts: 19
    Oil and Gas prices in Brockton, MA
    Oil prices - High 3.699, Low 3.29, Average 3.543.
    Over the weekend we had a gas station that hit 2.89 for regular for a very short time. The other day the lowest I saw was 3.03.
  • mtfallsmikey
    mtfallsmikey Member Posts: 765
    Here
    In the NW part of the great Commonwealth of Va.. Gas $3.45, diesel $3.89, dunno about #2, haven't bought any for 2 yrs. now..:}
  • Carol_9
    Gas war.........
    we have 2 stations within a mile of each other that keep trying to underprice each other. I went by them this morning and one was $2.83 and the other was $2.85, within an hour and a half both had dropped another 8 cents down to $2.71 and $2.73..........you should see the lines!
  • Larry C_13
    Larry C_13 Member Posts: 94
    #2 and cheap gas
    SW corner of NH #2 $3.99 Gasoline $3.45
    North Central MA Gasoline $3.35
  • oil and gas prices
    #2 oil is a low of $3.38 a gallon, with a therm of natural gas at $1.0403 a therm with a delivery charge of $1.24130 a therm.
    With a 117 therms used I payed $208.70
    This is in MA.
  • Frenchie
    Frenchie Member Posts: 113
    Gas and oil
    Here Oil is $3.70 a gallon for #2. Natural gas is 90 cents a therm including delivery. LPis $2.25 a gallon. I stuck a Natural gas conversion burner in my boiler this summer. I like oil heat better, but not at 4 times the cost. I'm not that retarded! This is in Wisconsin. Why is gas in MA $2.30 a therm delivered when mine is only .90 cents? I wonder what's up with that. Sounds like your utility is bending you over a little bit :)
  • Natural gas is so much here in MA. because much of it is delivered by tanker, which of course runs on diesel.
  • tim smith
    We are about a 1.48 all costs included per therm
    here in Seattle. #2 oil I think is around 3.50/gals but need to verify that. The nat gas price is based on my summer useage which is quite low so raises the avg cost per therm. Normal rate will be closer to 1.30/therm in winter.
  • Carol_9
    Are therm rates...........
    higher in summer or winter?
  • tim smith
    Not here but because of fixed costs and lower useage in
    summer the avg price per therm is effected. Tim
