Need someone to test CO, CO2, Draft on Gas Install
Steve Garson_2
Member Posts: 712
I just had a plumbing and heating contractor install a gas line and my Carlin EZ-Gas burner. Before I hired them, I specifically asked if they had the instruments needed to properly adjust the burner for CO and CO2 levels and was told "YES". Wrong!
So everything is installed and working, but I need to find someone to come in and set the correct weights on the atmospheric damper and adjust the air for correct CO. Since this is such a small job, I'm concerned that I won't find anyone.
I am in Newton, MA right at the intersection of I-90 and I-95 at the Wellesley/Weston line.
Am I correct in thinking that an oil heating pro can do the job just as well? (Assuming he has the instruments?)
Any suggestions?
Any suggestions?
Steve from Denver, CO
Have you tried: Find a professional, in the resource tab? I know there are some great guys up in your area.
I'll second that
If they don't use a digital analyzer they shouldn't be doing installation work. Use the Find a Professional page to get a real pro who will set that burner up right!
I already found someone as your suggsted. Thanks!Steve from Denver, CO0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
