radiant set back thermostats
realolman
Member Posts: 513
Can you use setback thermostats with radiant in the floor hydronic heat?
Would you want to?
thanks
Would you want to?
thanks
No. The recovery takes too long. Pick a temp and keep it there.Steve from Denver, CO0 -
PID
logic in Uponor 511s/tekmar equivalent makes programming do-able w/ radiant.0 -
Maybe
It depends on the thermal mass. My plates and pex-al-pex does a few degrees perfectly.0
