radiant set back thermostats
realolman
realolman Member Posts: 513
Can you use setback thermostats with radiant in the floor hydronic heat?
Would you want to?
thanks
  • Steve Garson_2
    Steve Garson_2 Member Posts: 712
    No. The recovery takes too long. Pick a temp and keep it there.
    Steve from Denver, CO
  • Bob Bona_4
    Bob Bona_4 Member Posts: 2,080
    PID
    logic in Uponor 511s/tekmar equivalent makes programming do-able w/ radiant.
  • Uni R_2
    Uni R_2 Member Posts: 589
    Maybe
    It depends on the thermal mass. My plates and pex-al-pex does a few degrees perfectly.
