Burnham SCG vs Buderus
Lil-Roc
Lil-Roc Member Posts: 50
look at the differences in them. Insulation jacket, heat exchanger, burners. Burnham is a quality product, but those Germans sure put out high quality products. I view Buderus like getting a Mercedes Bens at Chevy prices.
  • Steve_187
    Steve_187 Member Posts: 2
    BurnhamSCG4 vs Buderus
    Hey guys,
    I ahve installed several Burnham SCG boilers and have not had any problems. Buderus has an equivalent that gets 85% efficiency also. What's the opinion on the better boiler or do you think thay are similar. Prices are almost identical which I'm sure is by design.
  • Supply House Rick
    Supply House Rick Member Posts: 1,399
    If you haven't had a problem
    Why would you consider any other manufacturer?
  • JackR
    JackR Member Posts: 125
    I've used both
    I give the edge to Burnham, I don't think Buderus has the quality edge at all!!
