Burnham SCG vs Buderus
Lil-Roc
Member Posts: 50
look at the differences in them. Insulation jacket, heat exchanger, burners. Burnham is a quality product, but those Germans sure put out high quality products. I view Buderus like getting a Mercedes Bens at Chevy prices.
BurnhamSCG4 vs Buderus
Hey guys,
I ahve installed several Burnham SCG boilers and have not had any problems. Buderus has an equivalent that gets 85% efficiency also. What's the opinion on the better boiler or do you think thay are similar. Prices are almost identical which I'm sure is by design.0 -
If you haven't had a problem
Why would you consider any other manufacturer?
I've used both
I give the edge to Burnham, I don't think Buderus has the quality edge at all!!0
