Gas HTW Boiler With htw coil vs. htw Storage tank
Jeff_118
Jeff_118 Member Posts: 1
I'm trying to get feedback as to install a gas htw boiler with htw heater coil vs. a small Htw htr wall hung type /size with a seperate storage tank.What is more cost effective for installation and operating.Can you recamend some good products to install,i'm an a/c and heating contractor and don't usually install boilers or hot water heaters this is for my neihbor who has a small house about 900 sq ft 1 bath 1 person.
Thanks for the help Jeff
  • TONY_22
    TONY_22 Member Posts: 28
    Your Supplier
    Should be able to steer you in the right direction.Are you sure you want to assume the liability of installing something you are not familiar with??? If I were to install a furnace I would look for someone to at the very least make sure I properly size and install it!
    Lots of variables with hydronic heat and also lots of choices.
    Rich K.
