Gas HTW Boiler With htw coil vs. htw Storage tank
Jeff_118
Member Posts: 1
I'm trying to get feedback as to install a gas htw boiler with htw heater coil vs. a small Htw htr wall hung type /size with a seperate storage tank.What is more cost effective for installation and operating.Can you recamend some good products to install,i'm an a/c and heating contractor and don't usually install boilers or hot water heaters this is for my neihbor who has a small house about 900 sq ft 1 bath 1 person.
Thanks for the help Jeff
Your Supplier
Should be able to steer you in the right direction.Are you sure you want to assume the liability of installing something you are not familiar with??? If I were to install a furnace I would look for someone to at the very least make sure I properly size and install it!
Lots of variables with hydronic heat and also lots of choices.
Rich K.0
- 120 Geothermal
- 394 Solar
