Swimming Pools
Mike Thomas_2
Member Posts: 109
Radiant pools are a really nice high end. Two aluminum panels that sandwhich a styrofoam core. Life time, transferrable warranty. Been in business 50 years. You can even put one side in a bank if the yard is not level or put the whole thing in the ground and pour a concrete deck around it. They even have fiberglass steps like a regular inground pool. radiantpools.com
above ground Pool
Had a customer ask me where to get a swimming pool, they are looking for a 33x18 above ground pool, that they want me to heat with solar. I thought of NAMCO, but I have no idea where to send them, they want a quality pool. We have no local installers since you need to take a boat to get to there house. So I'm looking for some advice from some pool guys, I figured the Wall may have some pool owners, with some good feedback.I really could use the heating project.Any Idea's. Thanks in advance.0 -
On the internet
There are tons of sellers on the internet for above ground pool kits. Just search "above ground pools".
Some years back we owned a house with an inground pool and I used Leslies pool supplies. Bought all my chemicals and supplies mail order from them. They were very reasonable.
http://www.lesliespool.com/Shop
Good luck0 -
We sell 'em
Things to look for in above ground pools. Beaded liner, liner snaps in to a track at the top of the wall. Wall cove, triangular foam that goes at the intersection of the wall and floor. Install on a concrete slab about 1 foot bigger than the pool, saves install time, keeps the grass and weeds and moles away. Good sand filtration system 1.5 hp and 19 inches in diameter and name brand, like Hayward, Pentair, Starite. Find a dealer that has been in business for several years...0 -
got it
i've got an Ester Williams it has very strong aluminum sides that snap together like aluminum siding strips standing on edge much stronger than most with just rolled out sides0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
