photos boiler
Ed N.Y.C.
Ed N.Y.C. Member Posts: 73
back of the boiler in picture P1010375 next to the equalizer is a tap, looks to be 3/4" or 1" has a nipple in it now with elbow another nipple and a cap. Thats your place for skimmer valve ED
  • alan_8
    alan_8 Member Posts: 19
    Photos of boiler- problems seen?
    Here are 2 photos of my new boiler . Wanted input if anything looks out of place- i have had some say about the copper in header, that there should be a drop header, no skim tap, etc.
    thanks
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,290
    Seen worse...but it still leaves alot to be desired
    and should be repiped in black pipe. Could you take some better pictures...different angles , longer view, and resize the pics? Mad Dog
  • alan_8
    Photos Boiler Problems!
    Here are some other photos/views- any input would be appreciated. Should the copper pipe in the back be black iron? should the copper on top have been iron? Should there be a drop header? Should there be a skim valve? thanks
  • kpc_20
    kpc_20 Member Posts: 19
    if you look at...
    install manual is will show you better how to pipe it. Drop headers are nice but not required. The copper on the header should be replaced...equalizer ok. And why is the boiler so close to the wall? Skim valve? it looks like a skim "tap" is there. Is it sized right...looks like abig boiler....kpc
  • alan_8
    Photos Boiler
    Regarding closeness to wall, that is where the old one was (installed over 20 years ago) so when they replaced this recently they put it back in the same spot. House is a 3 story house- one pipe steam- they measured it and this is what they came up with for size. How about the copper in the back, does that need to be replaced with black pipe? They said there was no skim tap on the system. thanks, any other info would be helpful.
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,577
    vaporstat
    make sure you have a 0-16 ounce vaporstat to control the pressure--maybe they are on sale in the summer!!
    usually there should be more vertical distance from the waterline to the lowest horizontal of the steam main so check those measurements against the installation manual [downloadable from the boiler manufacturers website ]--nbc
