angle valve
Supply House Rick
Member Posts: 1,399
there is not much to fail on a 1-pipe valve. it can be repacked, if leaking from the top. it should never be turned off, even if new, as it will probably trap condensate. if you wish to turn the radiator off, just get a hoffman vent for it, and turn it upside down.
what is the purpose of the replacement?--nbc
Radiator valve replacement
I need to replace several 1 1/4 angle steam radiator valves on a one-pipe system (c. 1929). Living in the southeast, few retailers exist. Can anyone suggest a recommended brand and/or source for ordering?0 -
pex supply
they carry everything ----Click here: PEX Tubing - Wirsbo Radiant Heat - Taco Pumps - Radiant Floor Heat - PEX Plumbing Supplies0
