add on fins for baseboard
Ted G
Ted G Member Posts: 63
I don't know about the fins but you can buy enclosure less elements.
  • kensethwins
    kensethwins Member Posts: 4
    clip on or add on baseboard fins
    Does anyone know of a mfr of add on fins.A customer of mine is in need of these.
  • HeatingSolution
    HeatingSolution Member Posts: 2
    Add On Fin Solution
    There is a solution to this problem.  Its called Fin Clamp and you can find it by searching for fin clamp baseboard element in any major search engine.  It just clips on the outside of exposed copper.  check it out
    Thanks guys and have a great day.
