I NEED ADVICE ON REDUCING 4\" STEAM MAIN TO 3\" AND ELEVATING IT
bob young
bob young Member Posts: 2,177
you might consider welding a fitting with male or female connection. with proper layout & detail preparation it should go smooth as silk. i have threaded 4 " & 5 " by hand with a ratchet. [ not recently ! lol ] there might be an attachment for a 700 & drive bar. do yourself a favor & hire a pipe welder for the day. less work for mother
  • NEED ADVICE ON REDUCING 4\" STEAM MAIN TO 3\" AND ELEVATING IT
    here is the scene---4" steam main furnishing heat for 7 condo units in
    boston. need to reduce to 3" (with inspector's
    earlier consent) raise the whole line up 12-18"
    to get above new ceiling height and accomodate
    a new wall.
    question---is there an in-line threader like the ridgid 700 that can
    thread 4" steel while it's hung? i need to make the cut on
    the other side of a wall. i know i am probably dreaming
    when it comes to the threader, but i have used roust-
    about repair couplings before for 2" steam pipe gashes
    but can i make a cut on the 4" line, put on a 4" roust-
    about clamped to a small piece of 4" with a 4x3 cast 90
    , short piece of 3", to a 90 etc, etc. are roust-abouts
    legal in mass? the heat can not be down overnight so
  • Tony Conner_2
    Tony Conner_2 Member Posts: 443
    A 141...
    ... head will thread 2-1/2" to 4" and they can be driven with a 700 with a square drop in head. But those big heads weigh a ton. I'd second the welding option.
  • Brad White_185
    Brad White_185 Member Posts: 265
    Yes on Welding
    I second those who favor welding. Say "aye". May be a time to bite the bullet but overhead threading of inch and a half is bad enough... Some strategic pre-fab and ok, a fire watch detail but it will be done right.
    Condos are a tough business environment for sure.
    My $0.02
    Brad
