Riello F5 Burner
bob bona - i was just having a little fun... i just wanted to see what kinda of response from you people i would get with that kind of question... lol there's 4 possible suspects when the riello F series stays in pre-purged with immediate flame dropout... either bad, cad cell eye, control box, yoke, or valve stem... i just wanted to see how you guys would give an answers to that problem...lol sorry just having a little fun...
  • riello burner
    What could the problem be if the riello F5 burner constantly runs in pre-purge with immediate flame drop out???
  • Riello
    Try Replacing Eye First...if That Does Not Correct problem,Try Replacing Control Box.
  • Riello
  • riello
    i did that... what else can it be... ?
  • oh wait !
    should i just change parts, or maybe troubleshoot
  • wait a minute
    I thought you said in the other thread that Riello rules, Becketts are N/G?
    Hmm.
    Check the tab clips where the xformer slides in. Make sure they aren't spread apart too far. Check Hg. To start.
  • pre purge
    Any chance the cell is seeing stray light and fooling the control into thinking there is an existing flame?
  • The Riello Training guide says:
    Burner continues to purge and Lightoff with immediate flame dropout (530 SE Only)
    .Metal yoke coil missing
    .Coil wire #2 and #8 reversed
    .Low resistance of coid hoiding curcuit, terminals #1 and #2, (1350 ohms +/- 10%)
    Having no idea of that or what it means I pass on the information to you.
  • Riello
    Just ran into this on a brand new install. Turned out to be just a nozzle. Start with the basics.
  • make sure electrodes are properly adjusted, too close and the burner will not light, but stay in pre-purge
  • oh by the way
    that's a good try Marilyn you get 10 points lol
