Honeywell Supervent
Use part number PV020RP to replace air vent assemblies from 3/4-2" Supervents. Any hydronic-oriented distributor should have them.
  • Steve M_2
    Steve M_2 Member Posts: 121
    Honeywell Supervent
    On a call today I found a 1 1/4 Honeywell Supervent air eliminator leaking water out of the vent port. I pulled the innards and cleaned the float of gunk and reinstalled it. It still leaked and I cleaned it again and it still leaked. I closed the cap to stop the leak and told the customer I'd be back to take care of it under warranty.
    Can I replace the float and screw on assembly or should I replace it with a Spirovent?
    Thanks in advance.
    Steve
  • tim smith
    tim smith Member Posts: 2,886
    I have been able to get cap and float assy and replace.
