Honeywell Supervent
Bill W@Honeywell
Member Posts: 164
Use part number PV020RP to replace air vent assemblies from 3/4-2" Supervents. Any hydronic-oriented distributor should have them.
Honeywell Supervent
On a call today I found a 1 1/4 Honeywell Supervent air eliminator leaking water out of the vent port. I pulled the innards and cleaned the float of gunk and reinstalled it. It still leaked and I cleaned it again and it still leaked. I closed the cap to stop the leak and told the customer I'd be back to take care of it under warranty.
Can I replace the float and screw on assembly or should I replace it with a Spirovent?
Thanks in advance.
Steve0 -
I have been able to get cap and float assy and replace.
- 87.4K THE MAIN WALL
- 121 Chimneys & Flues
- 15.8K Strictly Steam
