thick slab over subfloor
gregrehn
gregrehn Member Posts: 9
If anyone has done a thick slab pour over a subfloor coudl you give some advice. Did you use the special mix, did you use a bond breaker, dimendions of control joints, did you force cracks with drywall corners? What about mesh over the tube?
  • greg_47
    greg_47 Member Posts: 9
    any takers?
  • Gordy
    Gordy Member Posts: 9,546
    First off
    When you say thick slab, and sub floor. How thick is the slab, and is the sub floor designed for this type of loading.
    Gordy
