Boiler Return Trap
Dan Mara
Dan Mara Member Posts: 3
I have a steam boiler customer with a tempermental return trap. You know, the one that uses the two check valves beneath it to direct the condensate when the trap fills and is activated. Does anyone make a replacement? Lost the brand and model. It is probably 50 years old and has the sight glass on it.
Dan
