Boiler Return Trap
Dan Mara
Member Posts: 3
I have a steam boiler customer with a tempermental return trap. You know, the one that uses the two check valves beneath it to direct the condensate when the trap fills and is activated. Does anyone make a replacement? Lost the brand and model. It is probably 50 years old and has the sight glass on it.
Dan
Dan
Boiler Return Traps
are seldom a prob if the pressure is very low, are you sure someone didn`t increase-it?
Dave0 -
They really aren't needed anymore..........
Nothing really goes wrong with 'em, but the check valves do get gunked up....and need to be removed sometimes. The best thing you can do is post a few pics of it and someone will help you out with it
