Water testing?
hot_rod
Member Posts: 26,602
because along comes rAy a cast iron condensing boiler streaming condenstae with ph of 4 or 5 across cast iron. With a 15 year warranty!
Did someone put muratic acid inside that boiler? PH low enough to hole through cast iron in 9 years must be raising h--- with the plumbing and faucets in that home. Probably eating the chrome of the brass fixtures :)
Something sounds fishy?
Local universities often have labs to test water.
Most pool supply companies have electronic testers that will give you a nice printout to submit.
Is it well or city water? Public water providers are required to have water quality data available to users.
hr
hr
Is there an independent water testing lab in the Northeast that I can send a sample of a customer's water to be tested for hardness, contaminants, etc.?
Thanks in advance, Adam0 -
pH factor in water Weil-McLain Boiler
I also need to test water- had a cast-iron Weil-McLain boiler installed in 1999 with a ten-yr warranty in an apt. building in Somerville MA. It started leaking this year, had to be replaced, showed corrosive holes(Have pictures), rep from Weil-McLain said warranty does not cover because high pH factor caused the holes to form thru the cast-iron.
Had to replace the boiler with costs over $26,000.
Trying to investigate if I have a case against Weil-McLain on the warranty. Need an expert opinion. Testing to date showed that the boiler is isolated from the system water; no indication that the fittings allowed any oxygen into the system, no stop-leaking compounds were ever used. Any advice?0 -
Adam look up National testing water laboratories and the product is called Water Check, very simple to use. Thanks Steveex0 -
For hardness, iron and pH you can usually get water samples tested free through your wholesaler of water treatment equipment. They give you a little bottle to collect a sample in and send it off to the manufacturer's lab. Results in a few days. For more extensive analysis, like for pesticides, fertilizer runoff, and bacteria you can google "water tests" I recently got a one shot kit for a customer concerned about her water that did everything i needed here: http://air-n-water.stores.yahoo.net/drinwatteski.html0
