Did Bock Change Something?
Dick Charland
Member Posts: 178
Though I have not installed one, I remember hearing a year or so ago that Bock had stopped using their "cement" chambers and were now using a "cerafelt" chamber. This could account for the difference, check out their web site, should have the info.
A friend told me that he tried to change out a Bock 32E tank only with the Wayne Burner with the fixed flange that was in the old tank. When he tried to install the burner the blast tube dimensions were different. The new tank had a different chamber material. Why after all these years would they change the chamber.One of the selling points of a Bock water heater was that you could easly use the old burner over again. If you have to buy a new burner as well as a tank you may as well buy a packaged heater from someone else to save money.0 -
You could also contact our friend General George
He can give you the staight scoop.
George M. Kusterer - Director of Technical Services
Bock Water Heater Co.
Phone (610) 683-9206
E-mail: Gmkusterer@cs.com
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"There was an error rendering this rich post.
- 167 Indoor-Air Quality
