You remember your first day on the job when...
Mike Dunn
Member Posts: 189
So I am working away in a corner of the basement when the apprentice comes over and tells me he's having a heck of a time trying to solder a fitting. Tells me the solder is repelling off of the joint. Come to find he was using pipe dope instead of flux. Made me think back to my first days on the job.
apprentice
Whe were working in a hospital running a ton of copper pipe down a long hallway, all sizes 2" and down i was cutting the pipe and had the apprentice fitting cleaning and fitting up all of the tees. after we went back to solder about 200 joints i couldnt get the solder to flow at all! The apprentice i had working behind me was using Victaulic greese insread of flux, he said they looked the same and didnt know the difference.0 -
i'll bet we all may
be able to remember when we were pipe dopes. and with my advancing age/eyes, i'm coming full-circle with some things. like today, mistaking a galv vent for pvc. i thought the purple cleaner looked weird on that 'pvc'.....0 -
Ouch
When the company I was working for was doing the basework at a hospital.The GC had put Big O sleeves in the footings for our drains. Some concrete had gotten into the sleeves so we sent a couple apprentices to knock out the concrete.I was working in the next room and heard "You hold the chisel and I'll hit it".Thank goodness we were already at the hospital.
DobberThere was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
