angel wing style hot water radiator
I have a hot water radiator measuring 23"L, 9"W and 27"H that has "angel wings" on the top of the ribs or fins. The wings are part of the radiator as originally manufactured. I want to know if I have a collectors item and if so, what the approximate value would be.
I appreciate anyone's help. I can be reached at 847-733-9805 or by email. Thank you.
  • Daniel_3
    Daniel_3 Member Posts: 543
    Post a picture of the radiator.
  • Dan Tomas
    Dan Tomas Member Posts: 3
    Angel Wing style hot water radiator
    I have a hot water radiator measuring 23"L, 9"W and 27"H that has "angel wings" on the top of the ribs or fins. The wings are part of the radiator as originally manufactured. I want to know if I have a collectors item and if so, what the approximate value would be. It is the larger radiator on the left.
  • Dan Tomas
    I just updated my post to include two pictures. Thanks.
  • Daniel_24
    Daniel_24 Member Posts: 1
    Hey Dan,
    They are not anything special. They are both A@R co. radiators. One is a high leg "corto" tube type radiator and the other is a fancy one that seems to be a "roccoco" but I can;t tell for sue as the middle column is shaped like the french ones that Burnham sells. The ornate one is fairly common and the tube type is very common.
