angel wing style hot water radiator
Dan Tomas
Member Posts: 3
I have a hot water radiator measuring 23"L, 9"W and 27"H that has "angel wings" on the top of the ribs or fins. The wings are part of the radiator as originally manufactured. I want to know if I have a collectors item and if so, what the approximate value would be.
I appreciate anyone's help. I can be reached at 847-733-9805 or by email. Thank you.
Post a picture of the radiator.0 -
Angel Wing style hot water radiator
I have a hot water radiator measuring 23"L, 9"W and 27"H that has "angel wings" on the top of the ribs or fins. The wings are part of the radiator as originally manufactured. I want to know if I have a collectors item and if so, what the approximate value would be. It is the larger radiator on the left.
I appreciate anyone's help. I can be reached at 847-733-9805 or by email. Thank you.0 -
I just updated my post to include two pictures. Thanks.0 -
Hey Dan,
They are not anything special. They are both A@R co. radiators. One is a high leg "corto" tube type radiator and the other is a fancy one that seems to be a "roccoco" but I can;t tell for sue as the middle column is shaped like the french ones that Burnham sells. The ornate one is fairly common and the tube type is very common.0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
